Well first off, after taking two hours to fit this thing, putting on the metal back plate and putting all the mobo back in a medi tower etc. The comp wouldn't start up and I realised the metal back plate was shorting it out, I should of followed my gut instinct and insulated it with the rubber gasket. But what ever turd wrote the instructions never said to do that.
Anyway after getting extremely angry and re doing it all again(in half an hour ) and got my comp up and running I wasn't impressed with the temps I was getting 51C under load on Prime95 with my system at stock settings. And it did vibrate a little at the start, what’s causing this? It can't be right and all the reviews said it was good and rated it a lot cooler then that. Have I not tightened it properly or something? It was quite hard to tighten it considering it’s right on and post and no room to do anything (they should have included the right size spanner). What do you suggest I do?
Cheers
Sam
