Hello!
Basically I am running two systems; my advent netbook, and my desktop pc which is upstairs. Three PC's and one Xbox connect to the huawei echolife 520b router talktalk gave us when we signed up in March. My mother's Netbook and my 360 connect fine, but my desktop has a bad connection and the netbook wont connect unless it's ethernet. The desktop im not too bothered about since it's for media, but the Netbook worked fine until I had to run a backup because of viruses!
I tried copying the settings from my tcp ip settings on my desktop which failed, my mothers netbook didn't have the settings there so im assuming it auto assigned it.
HELP!?
Ipconfig /all:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\DB>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DAVID
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : www 520b com
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : www. 520b.com
Description . . . . . . . . . . . : 802.11b/g Mini Card Wireless Adapter
Physical Address. . . . . . . . . : 00-1D-92-CB-E8-C3
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 0.0.0.0
Subnet Mask . . . . . . . . . . . : 0.0.0.0
Default Gateway . . . . . . . . . :
DHCP Server . . . . . . . . . . . : 255.255.255.255
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : 520b.com
Description . . . . . . . . . . . : Realtek RTL8102E Family PCI-E Fast E
thernet NIC
Physical Address. . . . . . . . . : 00-03-0D-A6-08-99
IP Address. . . . . . . . . . . . : 192.168.1.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : 31 July 2010 20:52:33
Lease Expires . . . . . . . . . . : 01 August 2010 20:52:33
