Results 1 to 9 of 9
Thread: Grenade USB; Part Deux
    Default Grenade USB; Part Deux
    Thanks to ozzylow for the inspiration. Sorry bro, I have to one up you on this.
    http://i86.photobucket.com/albums/k9...g?t=1286739583
    Primer coat applied. 32GB thumb drive internals with protective electrical tape layer. I decided to paint the grenade body black with the handle red. I decided to use a thumb drive that I already had to save a few $$
    http://i86.photobucket.com/albums/k9...g?t=1286783239
    Assembled everything for a fit test:
    http://i86.photobucket.com/albums/k9...g?t=1286785781
    For humor's sake:
    http://i86.photobucket.com/albums/k9...f?t=1286783906
    ATX Mental Case raistnox's Avatar
    Jul 2009
    Default Re: Grenade USB; Part Deux
    any plans on making it retractable?
    "it only takes one voice to start a revolution"
    Aug 2005
    Sunderland, Tyne & Wear, UK
    You might want to NOT try to take that on a plane :p
    Quote Originally Posted by raistnox View Post
    Maybe in the future I'll try and do that.
    Custom Title Honors Snowman's Avatar
    Jul 2008
    B F E
    What about internalizing it all and running a usb extension through the fuse area of the handle on a second version... just a thought.
    Regedit'ed, Rooted, and Jailbroke anymore questions?
    Here’s a bumper sticker I’d like to see: “We are the proud parents of a child who’s self-esteem is sufficient that he doesn’t need us promoting his minor scholastic achievements on the back of our car.”
    Actually, I plan on running an extension out of the bottom hole.
    Jul 2009
    i know pull the pin let the spoon go and out pops the usb that would be AWESOME... dont quite know how youd pull it off but sounds cool
    Anodized ozzylow's Avatar
    Jul 2010
    Sydney
    Definatly made it better then my previous attempt. I ended up scrapping mine, was not happy with it in the end. Wish i could get the same one asyou and build something from it.
    How much did that cost you
    It was about $8 at a local surplus store. I've since mofidied the usb grenade concept and incorporated an inert 40mm one (you can see it in my 2TB NAS ammo can build)
