Hi guys,
Figured ill show you my machine. It started out as a standard build with an Antec 900.....
I plan on building a whole new system next summer. This is my first baby, shes three years old, runs just as fast (if not faster, since I added RAID0) since the day i built it.
minimal cable management. boring. dull. UNTIL!!.....
Obvious black paint job.
Installed Zalman GFX cooler on my 8800GS
Much better cable management. I cut 3 holes behind my motherboard to route cables. the first hole is the big one on the bottom to route all power cables and front usb port cables. second hole is near the top for the 4pin CPU cable. third hole is for light switch, GFX fan, and rear exhaust fan power cables. the cables for my hard drives are also tucked away much better
Athalon X2 4800+ OC@ 3.1GHz
ASUS M3A78-T
XFX 8800GT 384MB DDR3
4x1GB G.Skill Ram 800 DDR2
(2) 160GB Seagate 7200RPM (RAID 0)
(1) 640GB Seagate 7200RPM
Antec 900 w/ 650W Modular NeoPower
Sunbeam 92mm cooler
ODD - Sony optiarc dvd AND lite-on dvd-rw
