I've been mulling my first real fabricated case for awhile. I've done minor things like sleeving, but nothing requiring any real power tools. My prevailing idea is to build the case into a desk. Not so much a case that fits into a desk, but a case where the top of the desk is the actual case. I was hoping I might be able to get some ideas and see problems others have run into in similar type builds but I havent seen much else of what I'm looking to do. I'm trying to make it as flat as possible, unlike the the ones I've seen which sink down into a desk.
Here are two extremely primitive shots of the sketch-up I've made:
The casing will be made out of lexan so that all the hardware, sleeving, water cooling will be visible. I'd like to think that it'll be nice to look at after the sleeving and tubing are lit up.
Of the several concerns and questions I hope someone can address and answer are:
1. I've never done something this complicated involving watercooling (only ever done one object in a box). I'd like to use both graphics cards, the processor, ram, and northbridge. Questions being, would I really need two different loops to cool all those components? What would be the best way to loop them together (ie: the cards in one loop and then the motherboard stuff in another)?
2. I know the flexible PCI extenders are available to move the graphics card "off" the motherboard, does anyone have any experience with these? Are there performance hits for the cards themselves? Can I chain them together to make a longer extension (the longest I've found is 6" I think)?
3. How the F do I make tubing in sketchup? For the life of me I cannot get it to come out correctly.
4. Anyone have thoughts on those UV invisible paints? It seems like some cool things could be done with that, but as expensive as it is I'd like to hear some thoughts before giving it a shot.
Thanks for any answers, critiques, suggestions you can offer. I'm sure I'll have more as I venture forth into this project.
