Results 1 to 3 of 3
Thread: how to calculate CFM if V changed?
    Apr 2006
    Default how to calculate CFM if V changed?
    Is there any wat to recalculate de air flow of a fan if i change the voltage?
    lets say i have this fan for example :
    Specifications:
    * Fan Size: 80x80x25 mm
    * Rated Voltage: 12 V
    * Rated Current: 0.20 A
    * Rated Input: 2.40W
    * Power Speed: 2900 RPM
    * Air Flow: 39 CFM
    * Noise: 34 dBA
    * Weight: 62 gm
    I want to plug it to 7V to reduce noise, how do i calculate the CFM?
    Nov 2005
    Scotland, UK (NOT England)
    Default Re: how to calculate CFM if V changed?
    Hmm...to be honest, i'd guess.
    My money's on 22.75 being your new airflow. It should be fairly obvious how i worked that out.
    -Dave
    Apr 2006
    thanks for your reply
    yes, i thought that too, 7*39/12, but thats only if its linear, can anyone confirm this?
  1. Low noise/high CFM Case Fans
    By Redundant in forum PC Cases, Tools, & Cooling
    Last Post: 12-05-2006, 01:03 PM
  2. Metropolis RED mod (title changed)
    By Vaantal in forum Works in progress
    Last Post: 11-20-2006, 03:19 AM
