How much can I get for a N64PC?
Hey guys, I'm still kinda new here so I hope I posted this in the right place. Anyway, I completed a N64 HTPC a few months ago and haven't gotten much use out of it . I'm thinking of selling it but I'm not sure yet, if you guys could tell me if you're interested, and how much you think it's worth, that would be great. Here are the specs, and I've attached some pictures. More info and pics of the inside are available upon request.
Here are the specs:
Motherboard - http://h20000.www2.hp.com/bizsupport...ctID=c00783647
CPU - Intel Core Duo T2500 2GHz
RAM - Laptop DDR2 512MB (x2)
HD - SATA 80GB @ 5400 rpm
(Also have an extra identical HD).
Thanks guys!
Custom Title Honors
Re: How much can I get for a N64PC?
it looks like a good job you've done there.
the problem with answering your question though, is since it is a 1 off item, pricing is nearly impossible.
you'd have to find someone who really wanted something like that and is willing to pay for it. obviously the peeps around here are the types that would rather build it than buy it.
in the short amount of time i've been on this forum i haven't heard much of anything about anyone selling their mods. hopefully you can get an answer, but don't be too disappointed if you don't.
Yeah I thought that might be the case, but I figured it's worth a shot anyway. Thanks for the heads up.
When it comes to builds like that you'd generally take the value of the used components. You generally wont make any money for time invested in the build unless it's for a client or if someone specifically wanted an N64 PC. Check out what the internals are going for on ebay then throw it up with a reserve set around that number and just see where it goes.
