Results 1 to 10 of 11
Thread: Bugger, why doesn't this work?
    Jun 2009
    Birmingham, AL
    Default Bugger, why doesn't this work?
    Why is it that all my sketches return fatal errors? I pull code directly off the website, alter it in no way, paste it into Antipasto (since I'm no longer working with a strict Arduino) and hit verify, and it pitches a *****. I'm trying to get a cut/paste of what's going on, but it seems to be insane.
    It seems to me that the libraries it wants (specifically the Twig LCD libraries from the Garden wiki) even though I put them in the right spot aren't being found. And I can't cut/paste the error. Given that i'm a n00b, what did I do wrong in putting it together? (software wise, I didn't put the AVR together.)
    Fox Furry crenn's Avatar
    In the shadows behind you
    Default Re: Bugger, why doesn't this work?
    Can you tell us more details about the error? Maybe a screenshot?
    Jun 2009
    Birmingham, AL
    It blinks its LEDs all right, but I can't get more code on. Dunno what I need to do.
    Instructions it didn't come with, yay.
    Use the official Arduino build 022
    Jun 2009
    Birmingham, AL
    Does it support my Illuminato?
    If it's using the default Arduino bootloader, then yes.
    Jun 2009
    Birmingham, AL
    I somehow think not.
    Chip is an Atmega 645, not 328. There s an FTDI chip onboard, some 0919-8 deal.
    Reading the instructions off the website, the Illuminato uses the Antipasto Arduino software to program the deal. They didn't even say update the Arduino core, so something's funny in there.
    You can add support for it though! http://www.liquidware.com/wikipages/...o_Installation
    Jun 2009
    Birmingham, AL
    Pardon me, my ignorance is showing.
    Hopefully, I'll have a sketch put together the next time I ask a daft question.
    It might be something else that is causing your issues, but I'm not sure.
