Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: LED load equalizers
    Custom Title Honors Snowman's Avatar
    Jul 2008
    B F E
    Default LED load equalizers
    I have recently started switching out a lot of my incandescent bulbs with led lighting in my car. The challenge I have is that what normally would be a closed circuit on a bulb is bleeding low levels of power to provide a dimly lit LED strips. i need a load leveler and am thinking that the price that autozone asks for one might be a bit high. Surely building one would be cheap and effective. Anyone got any ideas?
    Regedit'ed, Rooted, and Jailbroke anymore questions?
    Here’s a bumper sticker I’d like to see: “We are the proud parents of a child who’s self-esteem is sufficient that he doesn’t need us promoting his minor scholastic achievements on the back of our car.”
    Custom Title Honors
    Feb 2011
    Default Re: LED load equalizers
    what leds are you using? are they specifically led bulbs for cars? i have switched out the bulbs in two of my cars with automotive led bulbs and don't have that issue.
    Jul 2008
    B F E
    Yes sir, packaging even said may need load leveler for some vehicles. The load leveler looks like a basic ceramic resistor but frankly they are charging about 6 times what it is worth. The other are some automotive strip lighting that I used to replace the single 194 bulb in the corner of my trunk with.
    baaah. billygoat333's Avatar
    Aug 2007
    Idaho
    yeah, iirc all the load leveler does is add resistance to equal the power draw of the incandescent bulb you replaced. I am sure you can use a LED calculator to see what resistor to use.
    Quote Originally Posted by Omega
    ber is id elicous
    Custom Title Honors
    Feb 2011
    do you have an information center that tells you if a bulb is out?
    Jul 2008
    B F E
    Quote Originally Posted by xr4man View Post
    Thank god no, I got all the benefits of the mkiv body with all the feature benefits of the mkIII jetta simplicity.
    Custom Title Honors
    Feb 2011
    i guess there must be some other black magic going on with your jetta then. the only reason i can think of that there would be any current flowing to your bulbs without manually turning them on would be for an info center. but then again, VW isn't noted for their electrical prowess.
    Jul 2008
    B F E
    Here is my theory, engineers design for specs not real world. 12 volt incadessant volts will operate on +- 2 volts from 12, to that extent a LED will operate on much lower lets say 9 volts plus resistor you will still get enough to close the circuit and power the LEDS. They will light but seriously underpowered. I added two more strips to the circuit and am no longer getting a glow.
    either way got a picture of the resistors they sell:
    Jun 2008
    MA
    Funny...I replaced all my interior lights in my truck with LEDs and they all work perfectly. Guess that's what you get for buying a Jetta
    Jul 2008
    B F E
    Your right next time I will buy a mazda ranger, a mitsubishi cavalier, or a monaro gto. Car was never engineered for LEDs so complaining about its design is kind of like taking a house built in the 40s and expecting it to run your 220 welders and air compressor without doing any type of upgrading.
