Results 1 to 5 of 5
Thread: Review: Cooler Master Elite 371
    Jun 2008
    MA
    Default Review: Cooler Master Elite 371
    A new story entry has been added:
    [drupal=669]Review: Cooler Master Elite 371[/drupal]
    By Will Lyon
    Most cases you see these days are flashy, full-featured housings for your beloved rig. But what if you just want something understated? Something that will still perform? Enter cooler Master's Elite series of cases. Today we'll be looking at their Elite 371. Read on to see how it performs....
    baaah. billygoat333's Avatar
    Aug 2007
    Idaho
    Default Re: Review: Cooler Master Elite 371
    Good review, nice to see the cheaper range of ATX cases getting tested.
    Quote Originally Posted by Omega
    ber is id elicous
    Nov 2010
    Idaho, USA
    Well, I helped build a computer for a teacher.
    I do agree on the close-quarters of the graphics to the HDDs.
    One thing I might add, is the toolless things ARE removable. Just tales a little bit of wiggling.
    Tri.fecta
    Apr 2011
    I agree, its challenging to install a watercooling loop in this case:
    Dec 2011
    I have the elite 370 running beside as i type.It seems the same as the 371 featured here.The problem is that you cannot mount the 120mm fan inside the case on the top as the motherboard and cpu heatsink will block it's installation.Mounting on top of the case can be done only from outside the case.
    However,one has to attach the power cable from the psu inside to the fan outside so i used the expansion slots as an opening.It looks pretty weird but hey,that's life.If anyone have any suggestions to this problem,i am all ears.
    Thanks.
