Overclocked
Project : Synthetica by AnG3L
Intro:
Hello my friends again! Time for a new project!
This time I am going to follow my friends advice (Chris!) and replicate a design by the famous
architect Zaha Hadid!
This is not a copy of the design you are about to see but a replicate of her particular style!
It was a very difficult task for me to choose the perfect design amongst hundreds of beautiful
structures and buildings.
I had to take under consideration the placement of the components and the heat dissipation (airflow, materials etc)
This design though with the proper changes was the only one that fitted in my concept as all the other designs due to the very "free flaw" technique Zaha Hadid has, would have been huge and not so functional.
The other problem I faced was the finding of the right material. I choose so many materials but some of them were heavy, some of them needed molds and some of them werent durable enough. So I ended up with 2 different kinds of fiberglass and probably some modeling paste.
The main piece that I will work with will be acrylic, were I will do all the curves and crazy design with the fiberglass. The rest that will house the components will be aluminum. Most of the work will be done by using cnc and laser machines.
So far I worked around 200 hours on the designs and the concept. This mod will be watercooled even if I was going air this time I changed my mind due to the heat and aesthetic reasons!
All the parts are going to be removable, not a single rivet in my designs so far! As always I give emphasis first on the functionality.
The colors are going to be blue metallic and black!
So lets begin our 5th humble journey!! I promise that you will enjoy this as I have a lot of surprises for you! (No painting techniques as many people dislike them)
Overclocked
Re: Project : Synthetica by AnG3L
So lets begin!!
As I told you in the intro, the main part that it will word as a "top panel" will be the architect replicate theme.
The material I am going to "build" on it will be 3mm clear acrylic. A lot of windows will be attached on it and also radiator ventilation holes and mesh.
Here are the parts after the cnc "preparation!"
The main top panel piece was routed in the bending areas for more accurate and tight bend.
This small piece is a part of the reservoir stand! You will love it once I finish it!
Some windows will be bended too.
Some of the windows bended already!
This small 2cm acrylic piece will be glued together with 4 more the same to become the angle of the components chassis. This
will also hold the box together. You will have to be patient till we get there though!!
In 8 of them (top and bottom parts) I made threads for the screws that will hold the box together.
So lets cross our fingers for a nice journey guys!!!! Peace to all of you!!
Overclocked
So guys time to post the next update!!
As you saw in the first update/post I showed you a piece of clear 2cm acrylic that I am going to
use for the main chassis as corners and also as supporters for the aluminum construction.
I cut 20 pieces as they are going to be 4 corners 10cm each.
I had to face some problems though. The laser machine didnt cut the pieces right, so when the people in the acrylic shop tried to remove them from the main piece, they broke most of them.
Also they were cut pretty unshaped so my files and sanding skills had to take action.
Here are glued with acrylic cement glue.
The filing and sanding took me 10 hours in total as I had to fix the broken pieces also with isopon and titanium wait for them to dry sand again and repeat the process till I had the perfect shape. Unnecessary trouble but hey, we are modders we have to fix things that are broken!
Filing each side and then sand them with 150 grit sandpaper. One more problem I faced was that my mouse sander broke during the work and I bought a new Bosch one.
Isopon and titanium for maximum durability even though isopon was more than enough, my
perfection madness told me to use titanium too.
Finished shots for now. More to follow soon hopefully!
Next job was to sand the reservoir stand pieces and prepare them for assembly.
The pieces glued together with plastic welding glue. I also cut the 5mm acrylic rods that I am going to attach on the stand for... aesthetic reasons mostly!
Here it is fully assembled. As you might notice the edge of the acrylic isnt smooth due to the !#!@!%$ lasers machine bad functioning. So I will have to sand it and smooth it isnt it????
After 2 and a half hours I finished sanding the edges!! The inside of the circles its not though as it holds the reservoir pretty tight and I didnt want to mess with that. Here is the final piece.
Thats it for now guys thanks for reading my worklog. More to follow, hopefully soon as I need the hardware and aluminum pieces in order to continue!!
Overclocked
Overclocked
So Update no 7 its here guys!
I ve start working on the most difficult part of this mod which is going to take some time and that
is the main top part.
Here you will see the progress which is simple enough, yet very difficult in execution.
I am using fiberglass paste for the rough first fills and then Isopon 38 known as body filler for the finishing touches.
The design is really complex with many many curves and details. The angle of each curve its different (30 to 70 degrees) and I have to create a smooth curve to attach each and every one of them.
The progress requires sanding with grinding wheel, mouse sander, files and by hand.
After I finish sanding I add one more layer of isopon to cover any imperfections and holes and then sand again, then new spots are revealed so I repeat the process over and over again.
I estimate to finish this piece after 50 or 60 hours of work.
I will post the pictures without comments as I ve explained everything already! Enjoy.
Thanks for reading this worklog guys till next time, peace!
Overclocked
