This is what the rods are for, something solid to bend the acrylic against .
Made a start, mounted, drilled & tapped an angle bar for the acrylic to attach to for the bottom end, if I get chance tomorrow I'll finish off placing the cut down rods, cut a long thin strip of acrylic, bend it against it to find out precisely how long it needs to be & to see how good a curve I can do, then cut the acrylic piece & get it fixed on .
Now I'd better switch over the motherboards .
