Results 1 to 3 of 3
Thread: modding help
    Aug 2012
    Default modding help
    so i currently have a project i want to do, this is because i need to learn C at some point, the only way i'll learn it is with a project that i really want.
    basically i want to make something like the strike 7's display. while i can do most of the hardware, there is one bit i have no clue about, this being the screen. (the code will start of simply and get more and more complex to finally display what i want it to)
    the screen i'm looking at using is
    http://uk.rs-online.com/web/p/lcd-di...aphic/7422191/
    or
    http://uk.rs-online.com/web/p/lcd-di...aphic/7422202/
    (more likely the first tho)
    now looking though the data sheet (http://docs-europe.electrocomponents...6b8107926c.pdf), i have no clue about the interface it uses.
    it seems to say an parallel interface or an 16 bit data bus, however like i said i have no clue what they are? could someone point me in the right direction, this is something i really want to see made a reality.
    (this seems to show something like a sheild behind it, do i need one of them? http://www.ladyada.net/products/tfttouchbreakout/)
    Aug 2009
    Michigan
    Default Re: moding help
    Welcome to TBCS!
    Wow! I have no idea about any of this either but it's cool. I'll help you out by posting this pointless comment to bump you back to the top.
    I'll procrastinate tomorrow.
    Overclocked Neodymium's Avatar
    Jan 2012
    If I follow what you are asking properly...you can use C to do all you want to do..
    A parallel interface is used to connect to the microcontroller which in turn connects to the LCM (also known to laymen as LCD dot matrix display).
    Good place to start is to go visit the atmel site, has tons of stuff on programming microcontrollers, and not just using C. This link will take you to a page where it talks about 8-bit programming and microcontrollers.
    http://www.atmel.com/Images/avr_3_04.pdf
    Here's another link that gives you examples of code and how it can be written to display
    http://www.mikroe.com/esupport/index...d=137&nav=0,63
    In the first picture, if you see below the LCD, there is a microcontroller which connects to a parallel interface...you want to research for some more stuff on parallel interfaces to connect to a microcontroller and to your pc.
    Last but not least GIYF
    Good luck!
    Quote Originally Posted by Twigsoffury View Post
    measure for two days.
    cut once.
    In the pipeline: PRO-49776
