Results 1 to 10 of 12
Thread: 20/24-pin ATX female port (and metal plugs and tool)
    Nov 2010
    Idaho, USA
    Default 20/24-pin ATX female port (and metal plugs and tool)
    For my brother's overdone monitor (AKA iMac G5 shell), I'm re-using the PSU. It's a weird 22-pin connector, but it's almost the same physical shape of a 20/24-pin ATX connector. The electrical's a little different: http://www.xlr8yourmac.com/images/im...ply_pinout.gif. I just need a female connector so I can make it a little easier to interface into it. 20 or 24 doesn't matter, as the extra 2 pins, as you can see, are 24V, and
    GND.
    While I have your interest, I'm looking for a quick 2-wire system to disconnect a power switch.
    Tri.fecta
    Oct 2007
    Kinshasa, DRC
    Default Re: 20/24-pin ATX female port (and metal plugs and tool)
    Just but a used PSU.
    Nov 2010
    Idaho, USA
    Whoops, I got the male/female thing mixed up....
    Need the on-motherboard-style connector, lemme look for 'em.
    As for the crimper, would my automatic wire stripper work? It has crimper stuff on it.
    Tri.fecta
    Moderator TLHarrell's Avatar
    Jan 2012
    Morgan Hill, CA
    For ATX pins, you want a good crimper that bends the pins back into the wire insulation. This will keep it from falling out.
    http://de.mdpc-x.com/mdpc-crimping/mdpc-crimpzange.htm
    Check out the closeup pics of what the tool actually does with the pins.
    Jun 2008
    MA
    Nov 2010
    Idaho, USA
    Close, but are there any that have the the MB-side connector, but able to put individual wires in? Like for a custom extension cable?
    *Found it: http://www.performance-pcs.com/catal...4142df62063f1e and (wrong thing)
    I already have a bunch of fan-molex adapters, so that's taken care of. Just need to order the.... Other end *haha*
    http://www.performance-pcs.com/catal...oducts_id=1390 and http://www.performance-pcs.com/catal...4142df62063f1e
    **Less than $10... Worth a shot at sponsorship.
    Tri.fecta
    Nov 2010
    Idaho, USA
    OK, I found an old fan cable, so that's taken care of. Just need to find the ATX male pins.
    Tri.fecta
    Jun 2008
    MA
    http://www.performance-pcs.com/catal...ducts_id=20864
    Nov 2010
    Idaho, USA
    Take it I'm asking for something obscure?
    Yes, I do need the motherboard-side-style connector, but I'm pretty certain that those won't work.
    Actually, they'll work. Now, their sponsor email address. That something I have to find, or anybody know it?
    Tri.fecta
