I have a question for you guys. I can get older computers for dirt cheap. Are they good for anything? Can they be turned into a decent HTPC or a file server? The computers range from 386's to p3's.
What about a file server, a p3 should be good enough for that right? Lets say i got a p3, what would my best os be if i wanted a file server?
I have been testing FreeNAS for a while now.. http://www.freenas.org/ It works great! Takes only 16MB of disk space (so you could put it on a cheap Flashdrive and save your disk drives for storage), and has a web based interface to adminster it, so you don't need a keyboard, mouse or monitor once you finish the install.
Hope this helps ..
Or just use Windows XP. Im runnin XP on my P3 right now, and it runs about 25% faster than with 98SE or ME.
Or you can use NT for networking.
But note, for a P3, you may surely need an extra HD controller, to allows bigger sizes. If you are lucky enough, you may get an ABIT BE6-II motherboard, which has 2 controllers, for a total of 4 UDMA/66 HDDs and 4 UDMA/33 devices. Im having 3 HDDs and 1 CD drive (would have 2 drives if I wouldnt be missing molex splitters). But even then, HPT366 does not support more than like 80Gb of hard disk, or somewhat around that, I cant remember the right number. So you will probly need one of those PCI controllers.
I'm using windows server 2003 on a AMD K6 II 500 MHz system... works very good... and uses less resources than winXP ...
386's are fun to burn up or shoot.
FreeNAS looks like fun to play with.
run FreeNAS, Slackware Linux, or an other lightweight linux distro.....
dont run windows NT, youll get alot better performance with FreeNAS >_<
if you dont know how to use linux, go to a local computer nerd shop, and ask if anyone does, explain that your setting up a file server.....
or google around
-clay
Google is a better option. There's enough linux users out now to solve almost any dilemma a new user will have.
As for the 386s; try to see if you can overclock the **** out of them and take off the heatsink.
CPU go boom!
