Results 1 to 6 of 6
Thread: Im New and need cable advice
    Jun 2006
    Default Im New and need cable advice
    Hello everyone. Im new to the boards and Im pretty pleased with all Ive read so far. I need your advice on my cable managment. Any advice on how to clean it up further?
    What Ive done is mostly put the cables on the other side of the case. Any ideas on how I can make the psu cables look a little more um..nice?
    I know this isnt much of a mod but its a start for me. Next Im planning on maybe painting the interior of my case to a black but Im not sure yet.
    Water Cooled silverdemon's Avatar
    Jun 2006
    Delft, Netherlands
    Default Re: Im New and need cable advice
    try putting as much cables behind other things, don't bond them together as you did right now, cause you'll only have one huge cable running trough your case then. You can for instance put the powercables of your HDD behind the HDD-rack, that should make your pile of cables a bit smaller and better to handle...
    AMD RULES
    Guest
    well first thing I would like to say is that I have the same case and it is KICKASS awesome! I don't know what you think of it, but what I did is
    on the other side on where the hdds go, put your extra cables.
    (This is my AM2 rig in my sig)
    Rankenphile
    Guest
    Oh, and welcome to TBCS! Hope you enjoy your stay.
    Jun 2006
    Thanks guys. AMD Rules I routed most of my cables to the other side so its not a problem with those. Oh well Ill work on it some more tomorrow, with better pictures. Oh one more question, what do most of you use to clean finger prints off your cases? This black case is getting covered and Im thinking windex may leave streaks
    Nov 2005
    Scotland, UK (NOT England)
    I use a static duster and polish it by hand. You could always try kitchen towel as well.
    EDIT: Whoops, welcome to the boards!
    -Dave
