Results 1 to 10 of 15
Thread: Computer/ Art.
    Sep 2013
    Default Computer/ Art.
    I am currently working on building a computer that is inside of, what is basically, a custom made shadow box/ picture frame. I like the idea of letting the computer components speak for themselves. From the motherboard's complex circuits, to the simple exterior of a HDD, I have always felt it is such a shame to tuck these beautiful parts away into a computer case or worse, ruin them in a gaudy case that still just ends up under a desk. Art, is meant to be hung on a wall for display. And that is exactly the idea that I'm trying to bring to life. The idea seems simple enough but in practice it is taking a lot longer than I had originally intended. I told myself it should take around a week or so, once I had all my parts in the same place. Here it is, about 3 months later, and I'm still working away at it. Don't get me wrong I've been having a blast working on it, it's just been a little more involved than I had imagined.
    Troth for the lights routed out, holes cut for fans. Ended up going with a different fan set up for better cooling.
    Lights set in place to get a taste of what it is going to look when it's done.
    I have more pictures of further progress, but haven't uploaded them yet. I should be able to load those up pretty soon. I took a look around this website and saw what kind of insane talent that some of these guys and realize that I'm not even close to that level, but I thought it was a pretty fresh idea. This is my first build and just wanted to post it around and see what you guys thought about it. Just let me know what you think.
    Thank you,
    Scott Y.
    Feb 2008
    Default Re: Computer/ Art.
    It is an interesting idea, and I know what you mean on the shame of hiding away some of today's awesome-looking hardware.
    Carry on and show us more please.
    Moderator TLHarrell's Avatar
    Jan 2012
    Morgan Hill, CA
    Nice idea, but you're going to need a lot more ventilation in that case. Recommend opening up the top and bottom more and installing some mesh, and maybe some fans. That thing is going to absolutely cook otherwise.
    Why must hard drives fail together? TheMainMan's Avatar
    May 2008
    It's a really cool idea though I'm with TLHarrell on the cooling, assuming that you're putting a piece of glass in the frame itself. Are you going to mount it in portrait or landscape? If you have the ability to choose I would recommend landscape with the video card outputs at the top edge since the fan will exhaust out the back. For the other components the airflow direction likely won't matter as much as actually having airflow through the box. Are you planning on staining the wood?
    TheMainMan
    Sep 2013
    Yeah, as of now I have 4 fans mounted along the bottom of the case, 2 fans along the top, and a liquid cooling CPU set up with the radiator mounted at the top of the case. Also I have the holes cut to the full size of the fans instead of the small holes I had drilled out in the pictures I have posted now. I'll post more pictures in a few, I'm waiting for my phone to power back up so I can upload the rest of what I have done. It's set up to mount landscape, and I installed plexiglass into the frame. Oh and I'm applying a polyurethane finish, but I'm not staining it. Thanks for all the feedback.
    Thank you,
    Scott Y.
    A.B. normal msmrx57's Avatar
    Jan 2008
    Western Wisconsin
    It's is definitely a fresh idea, and looking very nice indeed from what you've posted so far. Looking forward to seeing more of this build.
    Now, off to the basement to do some fiddling with the rods and such.
    so far left of center i'm in right field
    Sep 2013
    Covering the inside with fabric for a cleaner, more finished look.
    Cut a line in the fabric and glued it back to make room for the LED strip.
    Frame finished, rounded off the edges with a router, and routed a track for the plexiglass, and applied polyurethane finish (not in that order).
    Frame and box finished (pretty much)
    Started installing "weather stripping" basically something to cushion the frame against the box to keep from vibrating, and something to keep the fabric from fraying at the edges there.
    The LED light strip that I have installed is an RGB strip that comes with a remote and can change between a bunch of colors and can even be set up to strobe, or slowly fade between different colors.
    As of right now, the frame attaches using 4 clips, but when I installed those clips I assumed that the weather stripping would have more give than it does. So the clips don't completely snap together. After I fix that I need to figure out how to hang this bad boy on a wall, I was thinking about buying a simple TV wall mount. Let me know what you think.
    Thank you,
    Scott Y.
    May 2008
    The green light with the red of the RAM and GPU trim looks very festive! The black fabric was a great idea as it makes the computer parts the focus. The best way to mount it in my opinion would be a french cleat. It would allow you to move it later as well as easily take it down in case you needed to swap anything out.
    TheMainMan
    Sep 2013
    Thanks everyone for the feedback. Just finished it up let me know what you think. I ended up going with an inexpensive but effective TV mount. Also, I ended up re-mounting the frame mounting set up that I had before so that it worked as I had originally intended. I installed Battlefield 4 to check out how well it could handle it and to keep an eye on temps. After playing with all but a couple of settings all the way up for about an hour or so the CPU's highest recorded temp was 39.5C, GPU max was 53C. The motherboard has 3 sensors, highest was was 47C.
    Thank you,
    Scott Y.
    May 2008
    End result is pretty cool! Nice work!
    TheMainMan
