I actually built my own cube case. I ended up tearing apart a super cheapo case for the drive racks and mobo tray, but heres some pics
heres a pic from the very begining when it was pretty much just a frame still..
I also decided to go with dual power supplies, mostly because i could. these turn on and power off together thanks to a lil rewiring, well worht it though. also note the sweet fan grills, and imagine those fans lighting up to blue
heres a good side view pic while the case is empty, you can see the blue fans with scorption fan grils and the two PSUs with their car casings.
time for the good stuff, post production pics..
Sorry for all the pics, but i dont generally get a real good chance to show this thing off. I ended up sleeving all the wires with blue uv reactive sleeving. all ide cables are rounded and uv reactive.
theres 1 blue cathode and 2 uv cathodes along with 4x 120mm fans, 5x 80mm fans (and thats not counting PSU cand CPU fans).
To control all this stuff i put in 5 switches in the front that light up clue when lit.
If you wanna check this out some more, i have it posted on my site, http://fusionmods.net - you can rate cases there, so if you join then you can rate the case, or upload your own to have it rated.
<<sorry, selfless promo, lol>>
