Hello all.
Newbie Moder Here. currently have two mods getting into the swing of things. one is mearly a paint and minor mod kinda thing( that i will put in a different work log later). but the one i am starting this worklog for now is my Tube Chassis Themed Case. the only pictures so far of the hardware to go into it. (to start) (will post soon).
Concept:
Main Rectangle tower Dimensions: 16"w x 24"l x 24"t
Complete with Tube Frame :17"w x 26"l x 26" t
Stainless Steel(or titanium not sure yet) Tubes that are set 1/2" every direcection suspending the tower inside of it. liquid cooling factored into the enitre case,a tottal of 3 resivoirs. all steel tig welded together. the entire cooling system will be Hose free and all Tubed steel. as well there will be motor mounts built and designed for the Mobo with a thermal pad or Tec to transfer the entire temp of the mobo to the case.
Hardware is a P4 3.0ghz 630 Lga775, 1gb ultra ddr2 pc4200(one dimm to start due to $$$) geforce 6600 (again to start due to $$$) Ultra Xfinitiy 600w psu (sli Ready), Asus P5W DH Deluxe (arriving this week)
Once the mobo arrives i will start cading it up.
On the top there will be a Radiator with a Hood over it that will Automatically open if the case reaches a dangerous level. on said radiator there will be dual 7" fans that will power up untill the tempature drops back to a safe level. on the front there will be a Grill that will open like a door to reveal the gagues and controls.
Would anyone have any recomendations of metals that may work well.
