Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Project: S-System
    Philippines
    Default Project: S-System
    “Project: S-System”
    Why S-System? If you’re going to think a word from the letter S, there’s a lot of idea you can think on your mind but for real there’s no meaning. Next System, basically the meaning is a “machine”. That’s it. 
    Introduction
    This is my 2nd project. My plan is to build a machinery control panel where it can control some things inside of it. Next the water cooling system, I will use some metal pipelines where the tube hose goes thru. I’ll place a security camera inside of it where it can view 180° on the psone LCD and some controlling devices to the camera. So there will be a limited vision inside the case. No plugs on the psu, I will make a direct connection to the controller where it can be power by on and off. And a direct ducting mod for the fans to look as a machine.
    I can’t make this project as on time due and easy, because there will be delay of delivering in some in parts. I ordered some computer parts on www.newegg.com but I will wait for 4-5 months before it will deliver it here, because they will ship first on my cousin’s house at California before my cousin deliver here on my location.
    So hard right? But it’s ok. Patience is a must. Geez. I need those parts to measure that thing on my project. As of now I will still continue to build my case. But I’m still in the middle of planning.
    Here’s the list I ordered:
    AMD Athlon64 3200+
    MSI K8N Neo Platinum (S939) & DFI UTNF4 Ultra-D (S939) for another rig
    2x Twinmos 1GB DDR400
    XFX 7600GT 256mb 128bit PCIe
    2x 160GB Seagate SATA
    Anyway here’s my new workstation room. And I’ve got a new rotary tool, jigsaw and drill.
    Here’s the plan! Anyway I will post my first plan here but not the others. Try to understand. If you notice that there is a vision on left panel and as I said the will be a limited vision in it, just wait I’m still in the process of thinking. And also about the plan was already 70% finish.
    Finally! August 9, 2006 I will start to mod for the lower case tomorrow and to born for the S-System RIG! .
    Please beware on my pictures. I used my camera on phone.
    Proud to be a Pinoy Modder
    Jun 2006
    Sydney, Australia
    Default Re: Project: S-System
    Lots of pretty cutting gear you have. Should be an interesting mod I can't really picture it in my head but it looks cool.
    Need a sig
    Philippines
    4:30am I woke up. its too early to start for the s-system project.
    while drinking coffee. I still continue for the plan.
    here's the material I used. metal angle bar, and aluminum angle bar.
    on the metal angle bar, as you can see there's a dent on the middle and i need to remove.
    that's it!
    measure cut measure cut measure cut... and more... LOL.
    now time to fit it all..
    Philippines
    **update**
    I finally used the acrylic sheet to cover the front lower case.
    preparing to cut using my jigsaw.
    the cutting session
    how sweet. perfect!
    another side.
    Philippines
    test it! test it! test it! perfectly fits on the angles.
    That's it for now. Thanks for looking!!
    Philippines
    time to drill and put some screws.
    Chicago, IL
    lookin good there mate. I love seeing people making use of angle channel . Looks like an interesting design. Keep the pics coming and good luck.
    Philippines
    thanks Aero.
    Jun 2006
    Sydney, Australia
    Very nice.
    Good to see a case being built from sratch.
    It all seems to be going along nicely.
    Need a sig
    Philippines
    that's it simon. even my plan looks like a stock case of desktop. i will definitely go for scratch
    thank you guys for looking on my project.
    nway my project have a lil' bit of delay due of materials. but I will canvass tomorrow how much I will cost for the next materials.
    thanks again.
  1. Project Nighthawk: Skunkworks F117-A Worklog
    By Crimson Sky in forum Paul Capello's Worklogs
    Last Post: 02-17-2009, 05:26 PM
  2. Project DEEP PURPLE (The Introduction)
    By modding.fan in forum Works in progress
    Last Post: 04-16-2007, 02:36 AM
  3. Operating System Project
    By progbuddy in forum Operating Systems
    Last Post: 10-07-2006, 11:45 AM
