I got a friend that needs help with problems that he is having with his PC.
This is what he told me:
"The ASUS motherboard P5AD2E-Premium comes up speaking an error "System failed CPU test" and after turning the power on and off form the swwitch on the power supply unit varying anywhere from 2-15 times or so it will finally beep and continue normal system startup with no problems at all, performance is unaffected, however the DVDBurner had stopped reading shortly before this error began, and now it will only burn whenever the computer is started with a blank disc inside. Is this related to the motherboard error?"
He is also going to switch out the CD drive this Thursday to see if that helps.
Can anyone help us please?
