Results 1 to 10 of 15
Thread: water cooling setup
    Chester UK
    Default water cooling setup
    do you think this is a good setup for my watercooling
    res-pump-triple rad-cpu-triple rad-gpus-double rad-res any thoughts welcome
    D'Oh
    Aug 2005
    .5m from my PC
    Default Re: water cooling setup
    2 triple rads+double rad.. 1 pump.. could be difficult pressure-drop-wise.. even if they are onepass low-flow ones.. and the best thing would be pump-cpu then the rest.. still, very nice radiator "power".. but i'm no expert
    Chester UK
    i could put two pumps in if thats possible
    D'Oh
    Aug 2005
    .5m from my PC
    everything is more than posssible! browse around the net and you'll see people using huge pumps, no rads and a reservoir of 1000+ gallons (search for a guy who made his setup in his basement, with custom made by him blocks, custom pipes >1/2" and totally fanless). u could use 2 nice pumps in the "middle's" of the loops.. i think this would be better than one big pump... keep the flow constant and stuff.. also, i've seen a weird thing looong ago for just one pump.. if u have one-pass radiators, u could run them in parallel for an even lower flow rate.. this is different than running a double-pass as an even lower pressure drop occurs.. the experts in cooling may give their oppinios, as i only got faster to this thread and am by no means trully qualified to give advice (i'm an air cooling freak)
    Chester UK
    well thanks for your help any how
    MitaPi
    Guest
    You should look into dual pumps. Or have 2 kits, one for your cpu and one for the gpu and other things. You will probably have problems with that much stuff and only one pump.
    Chester UK
    any ideas were to puit the second pump
    ATX Mental Case craigr1982's Avatar
    May 2005
    Leicestershire, UK
    i would put the 2nd pump before the gpu's but that just me.
    Again not a watercooling expert, just happened to be around.
    Craigr1982
    Redemption HTPC Scratchbuild- Zotac 9300 ITX, Intel Q9450, 4Gb G.Skill 6400, LG Bluray Drive, OCZ ModXstream 400W, 2x 1Tb Samsung, Windows 7 Home. 32" Toshiba LCD TV.
    Case Wizard
    California, USA
    I don't think you need the first triple rad in that setup you got there.
    Chester UK
    i know i dont but iv got two already from two previous pc so i might as well use them
  1. Custom Cooling Setup
    By FyR in forum Modding Q&A
    Last Post: 06-11-2006, 05:50 PM
  2. A Modders Guide: Watercooling
    By tybrenis in forum PC Cases, Tools, & Cooling
    Last Post: 04-13-2006, 09:41 PM
  3. HDD Water Cooling?
    By hxcguitarist in forum The Rookie's Nook
    Last Post: 01-23-2006, 09:10 PM
  4. Water Cooling
    By Viper-Inc in forum The Rookie's Nook
    Last Post: 12-29-2005, 08:35 PM
  5. Odyssey into Water Cooling
    By Dispatch in forum PC Cases, Tools, & Cooling
    Last Post: 08-31-2005, 07:21 PM
