Results 1 to 10 of 19
Thread: Someone help me NOW!
    Razors Edge
    Guest
    Default Someone help me NOW!
    Damn I post a topic here asking for help, you guys stop by here, read it then just go away without helping me. This is what I need.
    A motherboard that
    -Supports Pentuim D -LGA 775 (socket T)
    -Supports 184 Pin DDR
    -DDR2
    -AGP 4x/8x
    -PCI-E x16
    Did anyone find a motherboard that does this? I've been searching for 3 hours.
    ...What? progbuddy's Avatar
    Aug 2006
    Matthews, NC
    Default Re: Someone help me NOW!
    well thats specific.
    Thats why the world has google. lol.
    Case Wizard
    California, USA
    To have all those on one board is rare to non-existant. This is the closest I have found which you probably already saw in your search.
    ASRock 775Dual-VSTA
    Only thing off is the PCIe x16. It has a PCIe x4...
    Razors Edge
    Guest
    Yes I an hour on that mobo alone. I googled it, Google doesn't like me today. I don't like the x4.
    Blunt Master 5000 CanaBalistic's Avatar
    British Columbia, Canada
    Quote Originally Posted by Razors Edge
    -DDR2
    -AGP 4x/8x
    -PCI-E x16
    P5VD2-MX
    - Intel LGA775 Pentium 4 CPU
    - Support Intel® Presler 65nm Dual core and Core™2 Duo CPU
    - PCI Express architecture
    - DDR2 533/400
    - Dual SATA RAID (RAID0, RAID1 & JBOD)
    - External SATA on rear
    - High Definition Audio
    You Dont Spread Democracy Through The Barrel Of A Gun.
    Case Wizard
    California, USA
    I saw that Asus mobo too but the PCIe runs on in x4 mode too.
    I saw other boards close to what you want but they don't support Penium D. So I guess it is either Penitum D support or go with PCIe x4.
    No, it runs at full x16
    PCI Express Architecture
    PCI Express is the latest I/O interconnect technology that will replace the existing PCI. With a bus bandwidth 4 times higher than that of AGP 8X interface, PCI Express x16 busperforms much better than AGP 8X in applications such as 3D gaming.
    Jun 2006
    Sydney, Australia
    Sorry Cana-Balsitic but normally you would be right execpt on boards that run both AGP and PCI-E due to the special chipset required the PCI-E bus can only run at a maximum of 4x.
    I have seen reviews and in most games people using a PCI-E card 4x only drop a couple of frames comapred to a board with a 16x PCI-E slot.
    Need a sig
    Razors Edge
    Guest
    So if I buy ANY BOARD that has both AGP and PCIE, the PCIE is only 4x?
    ALSO can 4x pcie support the x16 videocards?
    Aug 2006
    Belgium
    I doubt it.
