Hello all! Today, I will start out my first Worklog for my currently unnamed project.
Introduction
Well, my first mod is coming to a close (I will post pics. as soon as my parts arrive) and I wanted to start another. So, I did. The origanal case is from an eMachines T2625 or something like that. Anyways, right now, the case really has no theme, and I'm kinda just doing things as I feel necessary. Please note, I currently don't have much money, so buy paint, Dremel bits, and other essential things will take a while. But I will update as much as I can.
Now, on to the pictures!
Started masking...
Ran out of the thick masking tape so I had to finish with thin stuff.
Design... (The purple areas will be cut out)
Had to get rid of those stupid indented vents or whatever they are supposed to be. Where they used to be, mesh (or in my case gutter-guard because it's really cheap) will be going in its place. I am keeping the vertical bars though.
The kincks and scratches in the last picture can easily be fixed, so don't worry about that.
As for paint and everything, I think I will do the outside matte black, the inside matte white (if there is such a thing), the mesh on the panels white (to contrast with the black) and have the windows covered with my white plexi. The other panel for my case is a wrap-around type thing with the top of my case, and I think I want to keep it that way. I will probably cut something on the other side, I just don't know what yet.
Well, later today I will cut out the rest of that panel, sand it, and prime it if I have any primer, so check back for updates soon!
Maleficus
