Results 1 to 8 of 8
Thread: Frosted plexiglass.
    Sep 2006
    Bordercity
    Default Frosted plexiglass.
    Working on a sidepanel for a mod I've been throwing around, I've attached an image to show you sort of what I'm talking about.
    I created this graphic using Paintshop Pro to make the panel texture and SketchUp to make the 3 dimensional image.
    What I hope to do is to frost the flames and nvidia logo, leaving the main bulk of the nvidia logos shape unfrosted. Just the border design around it and the actual nvidia symbol.
    Also I hope to leave the black parts unfrosted having them instead just clear plexiglass.
    My question is..how would I go about this? Mask off the parts that I don't want frosted with some sort of tape, I doubt masking tape would work as I don't see it holding up very well under a wetrub.
    With the addition of focused LED lights mounted somewhere inside the case I hope to illuminate the flames/nvidia logo with blue while having a lighter possibly white light shining through the unfrosted part.
    Any input is much appreciated as I see alot of plexiglass work on these forums.
    Eventually I'd like the entire case to be done in a white/blue sort of style and all plexiglass.
    The name I'm throwing around for this mod is "FrostFire" in hopes that I'll be able to make it run as cool as possible. "FrostFire" is a good natured jab at ATi's "Crossfire"
    I'm really at a loss as to how to go about this, currently working on making a detailed mock-up of my laptop window mod at the moment, so many projects..so few dollars to get them off the ground.
    But payday comes twice a month!
    "The way you post reminds me of Tom Hanks in the Ladykillers" - mrbona2
    HS religion teacher: "What do you hope to give the world when you die?"
    Me: "A large smoking crater"
    Overclocked
    Aug 2006
    Default Re: Frosted plexiglass.
    get the plexi etched. theres places to get it done cheap.
    ...What? progbuddy's Avatar
    Aug 2006
    Matthews, NC
    I frosted plexi with Dremel Polisher...
    Super Secret Agent
    Glasgow, Scotland
    Something that I found out years ago....
    I frosted some perspex by spraying on artists pastel fixative spray. The advantage being that you can mask off the area you wish frosted and get an accurate area of perspec frosted.
    www.Justblair.co.uk My depository for electronic projects and articles
    Overclocked a.Bird's Avatar
    Sep 2006
    Ithaca, NY
    Quote Originally Posted by justblair
    Really?? I just may have to try this now. Do you know if the frost will scratch off easily or get smudged? Thanks for the hot tip.
    Super Secret Agent
    Glasgow, Scotland
    Yes. I did it years ago by accident. I was using an acrylic pen holder to wieght down some fine tissue (I used to enjoy a bit of art) when i sprayed, it frosted and stayed frosted despite my effors to unfrost it....
    I had been htinking about trying this again recently. Though I was going to try it with matt varnish this time.
    I think a light even coat would do it
    Jun 2006
    Sydney, Australia
    I just use a can of frosting for glass that people use to make like christmass display's on the window's of there shops. It works well and is cheap.
    Need a sig
    Overclocked
    Aug 2006
    yeah, but it rubs off dead easy.
  1. Plexiglass
    By Vanquish in forum The Rookie's Nook
    Last Post: 03-05-2006, 10:34 PM
  2. uv plexiglass
    By DeathCrush in forum Modding Q&A
    Last Post: 12-03-2005, 01:31 AM
  3. plexiglass shapes
    Last Post: 11-24-2005, 01:16 PM
  4. Cutting Plexiglass, a few questions
    By NeroZero in forum The Rookie's Nook
    Last Post: 07-19-2005, 05:35 PM
  5. How to etch plexiglass
    By R/C Pilot in forum Modding Q&A
    Last Post: 04-07-2005, 09:43 AM
