Results 1 to 10 of 12
Thread: Gunsmithing-Style Engraving
    Default Gunsmithing-Style Engraving
    I was thinking about "the next big project" and something I thought would be interesting, would be faux engraving work like what's found on antique weapons, etc. Some examples are below.
    EXAMPLES:
    From a a site that restores antique guns:
    Before a gun is engraved, the design is done on paper, usually enlarged to about double size, then it is photo-reduced and transferred to the metal. The following is a partial design for a 1924 Colt pre-Woodsman. The top section is a side of the barrel. The lower section is the top round of the slide. This is a version of "American" scroll I developed about 15 years ago. The style works well on more modern pieces.
    The Ghostwheel Project
    "A lot of theoretical crap involving space and time and some notions of some guys named Everett and Wheeler."
    :: Spectre : GHOST 38.1 Mk1 : GHOST 38.1 Mk 2 : GHOST 38.2 ::
    rest in peace mate GT40_GearHead's Avatar
    Ramania
    Default Re: Gunsmithing-Style Engraving
    so you did this stuff
    (the vessel i just astonishing)
    LOUD AND PROUD !
    Life is like an analogy...
    Feb 2006
    Vancouver, BC, Canada
    i wouldnt necessarily call that faux engraving. its just engraving. as soon as you start chipping or cutting away in a decorative manner, its engraving.
    there are special tools for this sort of thing. one of them is just like a tattoo device, except the "needles" are hard enough to engrave steel. if you go to a metal or arts shop and ask around you may find one. they arent hard to work with at all once you get used to the feeling of the tool just kind of floating there. thats what it feels like because its striking the metal so fast.
    go for it.
    Quote Originally Posted by Slug Toy
    im pretty sure i was your car, but i was into mah music and didnt think too much of it
    May 2005
    MO
    That's going to require patience and a lot of skill. Very unique idea though.
    Engraving is one of my favorite metal artforms, particularly on firearms. I love 1800's spanish engravings.
    I would personally test on scrap first if you get an engraving set.
    Go for it, and post your worklog here.
    I didn't make those GT40_GearHead, was just linking to them as examples.
    As for the rest, what I'm thinking is, I would likely need to add some density to any case I did this with, maybe layer on some Bondo and then do engraving into it. I think I'll grab a couple of books on the subject and go from there.
    Water Cooled
    There are lots of ways to decorate metal.
    You might want to consider acid etching. They used acid etching for all the patterns on all the swords and Sauron's armor in Lord of the Rings. It works great on flat surfaces. You draw your design onto the metal with a resistant material (called a "resist") it can even be vinyl stickers. then you use an acid to remove a little of the metal around the pattern. It wont deform the metal like chasing or engraving can.
    Feb 2006
    if you try to engrave bondo, you'll need engraving tools other than the one i was talking about. try "tattooing" bondo and you'll have chips flying everywhere and it wont work.
    i forgot about acid etching. it does work good. you can do that to glass too.
    Hmm, thanks for the feedback guys. Lots to consider, I'll let you know what pans out after I'm finished with Infernis and get to work on this.
    Case Modding MoFo Crimson Sky's Avatar
    Jan 2001
    Brooklyn, New York
    A guy made a gorgeous cube PC made from 1/8" copper sheets--he scanned some pics of antique engravings and acid etched it onto all the sides--was fantastic and he did it in his kitchen.
    Ramania
    could we have a link to it ?!
    LOUD AND PROUD !
  1. Making your very own Bullets! (Prop style J)
    By Drac998 in forum Your Mods
    Last Post: 12-04-2006, 10:45 PM
  2. out of ID's (gothic style)
    By Nemo in forum Idea Zone
    Last Post: 06-05-2006, 05:32 AM
  3. Custom Painted PC Case/Antec CoD 2 style
    By Clausenlt in forum The Trading Post
    Last Post: 03-22-2006, 10:31 PM
  4. military style toggle switch covers
    By FynexFox in forum Modding Q&A
    Last Post: 03-11-2006, 03:07 PM
  5. metal engraving
    By lastweek in forum Modding Q&A
    Last Post: 01-11-2006, 12:33 PM
