im about to be putting a watercooling system in my dads computer...he has a visiontech ati1300 pci-e card..... i was lookin around for a block to fit it...are there any recommendations?
You're probably going to have to go with a more "general" waterblock. I don't think you'll find anything specifically made for a 1300. DangerDen has an assortment of MAZE blocks, however I am not familiar with the 1300 card.
Basically what it comes downt o is how the block is held onto your GPU card. You have to ask, where are the holes in your GPU that would allow you to run the bolts that hold down a waterblock?
Project: Savage (in progress)
Lian-Li PC-70 | Intel Core2Duo E6600 | Swiftech Storm w/ MCP655 Pump | P5W DH Deluxe | 2GB Corsair DDR2-800 | X1900XTX 256MB w/ Maze4 Waterblock | Audigy 4 | WD Caviar 300GB HD | WD Raptor 36GB HD | 2xslot-load DVD+RW slim drives
