ok, as im almost finished my desk'd mod, ive started getting ideas for my next one, which i hope will be bigger and better then the previous.
the mod will be a scale model of a B2 Bomber(stealth bomber, for those of you too lazy to use google)
ive just made a lifesize wireframe of it on the floor using bonzai wire, and checked to make sure all the components will fit, its a tight fit, but they do manage to fit in.
i plan to use only slimline stuff, as i cant really fit anything else, it will have to be watercooled as again, normal heatsinks and such wont fit as there just isnt enough height(total height at the lowest-highest point is 140 MM.)
im going to put 2 slim 120mm fans(ive seen them around, they are 12mm thick instead of 25mm) in the port things they have on either side of the cockpit(diagram will show what i mean)
the outside of the case will have a blue glow to it, as there will be blue LED's spaced about 50 - 80mm apart around it, with silicon sealant to diffuse the glow(check the diagram to see what i mean)
1 slimline DVD drive and 1 slimline CD drive on each wing
2 red LED's in each of the afterburner ports( http://www.richard-seaman.com/Aircra...B2AndC1302.jpg )
ill have to put the wheels on it, as otherwise it would just fall to 1 side...
there will be 2 HDD racks(each capable of holding 2 HDD's)
1 under each of the ports on the front(under the 120MM slimline fans)
http://www.aerodesign.de/nurflugel/B-2_front.jpg
the cockpit will be frosted perspex, with an LED behind each window(there will be 2 windows, see diagram) green for on, red for HDD light
PSU will be chopped up(i.e. outside its normal casing) and stuck in the back at an angle.(i might have to use a shuttle PSU)
NOTE: diagram is very badly drawn, i dislocated my finger today, and am coming down off dexamphetamine, my mind is off in fairyland...
tell me what you think
the inspiration for this mod actually comes from nighthawk, but i didnt like the "cockpit" look, so i went for the whole plane look
