Right before anyone says I know that XcOM has explained about heat shrink already in his amazing guide but.....
Does it matter what type of heat source you use?
I am thinking of using a blow torch would that be ok if I spread the heat evenly and did not hold it in one place too long?
Aswell do you only have to buy the tubing and thats it (as long as you get the right size)?
Thanks alot
-gaz
