Here is my project invalid li
Lit Up
Lit Up
looks nice. may be clean up your wires?
whats that metal showerhose doing there? good job btw
Beautiful. Nice case hardware, wared ja gitit? Like the shower hose as well was that Orac inspired? I like the clean window with bolt on look.
Thanks. Sadly for some ungodly reason all of my cables seem to culminate in the same spot. I can't find a way to make it better. Thats even why in the final version I removed the shower hose. Too much in one spot.Originally Posted by MrSlacker
Its carrying the wires to the top fan and the top UV cathode. The switch was then going to be mounted in the front. But when I got it all together all the wires were in the same spot, so I removed it to free up the space a bit.Originally Posted by Frakk
Thanks. The hardware was gotten at mnpctech. Both the chrome handles and the chrome rings. Great products. I was one of the first to install the chrome rings I got them before mnpctech stocked and sold them. The hose most definitely was inspired by Orac. The window I really like as well.Originally Posted by Gonzo
All that I have left now is my appliques. I designed them myself and it is the logo for my name. They look like this:
looking good. where r u gonna put the decals?
your cables ahve a lot of slack. take that V5 cable on the bottom and pull it to the PSU. make a straight line w/ it. same goes for every other cable, you have to pull them and use zip ties to hold them. you can also try ribbon IDE cables (flat ones) and hide them behind mobo. they are much more flexible and you wont notice them.
The logo with the title in it will go on the window bottom right.Originally Posted by Frakk
The full invalid logo of the skull will go on the black acrylic on the inside. Only part of it will be seen. Should be cool.
Will try some stuff in the future.Originally Posted by MrSlacker
Looks pretty nice, I won't pick at your cable management.
Mine is worse.
lol thanks X. I may be switching PSU's soon and if so, it will be a great chance to try to clean up more wiring.
invalid laboratory:
AthlonXP 3200+
2gigs Corsair PC 3200
XFX Geforce 6600GT
Seagate Barracuda 160gig HD
MSI K8N Neo2 Platinum
