How do I adjust my graphics card fan speed? I want to put mine on 100% all the time.
My Reviews
Logitech G25 // Razer Barracuda AC-1 // Gateway FHD2400 // Logitech G9 & ID Grip // Xbox 360 HD-DVD
Scythe KAMA-Meter // Sceptre X20WC
Well I know one way... Fan controller. Do you have one? Just plug it in and there you go...
I'm not sure if there is a setting in the bios or whatever that you can change so it's on full force 24/7. I think thats why people buy fan controllers though right? Because otherwise you can't? Maybe I am wrong.... I am not myself today. "Dumbest human being alive".
This might work for you??
http://www.newegg.com/Product/Produc...82E16835118217
-SF
No, I always hear people talking about adjusting the speed on their Graphics Card Fans, what program do they use?
My Reviews
I think ATi Tool has fan speed options depending if your card supports manual adjustment. If you have an nVidea card i dont know... does coolbits have fan control in it?
ATI Tool - "Overclocking with templates including FAN Control"
nVidia Tool - "Adjust GPU settings: Change GPU clocks and fans."
Hope one of those helps you!
-SF
My Reviews
