hey guys, how do i put my HD in? There aren't any drive baskets so i can't figure it out.
PS: here my HD and case are:
http://www.newegg.com/Product/Produc...82E16811144103
http://www.newegg.com/Product/Produc...82E16822148140
The links are dead. If there are no brackets is there somewhere you can screw them in?
Need a sig
here ya go:
Seagate Barracuda 7200.10 (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - $94.99
APEVIA (ASPIRE) X-Plorer ATXB8KLW-AL Black/Silver Steel ATX Mid Tower Computer Case -$59.99
they can fit into the things that u put the floppy drive into? should i put it there.
Lol when I click on the links this address comes up in the add bar as
[HTML]
http://www.newegg.com/Product/Produc...82E16811144103[/HTML]
Here is the right link
Case
HDD
I see what you mean. So there were no brackets supplied. With either the case or the HDD?
You can put it in the bay with the floppy drive fine.
Need a sig
nope no brackets.... so no problems i should be aware of about puting it next to the flopy?
no. thats where i put mine before i bought a case with brackets. btw you have a floppy permenantly installed? I only attatch it when i'm messing with the BIOS(updates), but thats usually a one time deal, then I never use it again.
You should be able to screw the HDD in the area I highlighted.
thats what i thought but my hd screw holes dont line up! im just putin' it next to the floppy...
OFF TOPIC/DONT WANT TO CLUTTER FORUM WITH NEW THREAD:
Do I need to buy like a surge protector or something? is there anything i should consider buying?
surge protector is a must. UPS(look it up on newegg for explaination if you need) is another good thing to have but not needed nearly as much.
