Results 1 to 7 of 7
Thread: Psu Help!?!?
    Nov 2006
    Default Psu Help!?!?
    Hey Guys,
    My PC is done (thanks for the help.) NVidia Sentinal has told me that my 620V Enermax Liberty won't give enough power for optimal performance. Apparently my 12V amperage is 22 and should be 26 Wow, power hungry BFG 7900 GT OC. I need some recommendations for a PSU like this. Hopefully Keep it under 200. My RMA expires in 10 days so PLEASE be quick with responses.
    -ARDEN
    Oct 2006
    Spokane, Washington
    Default Re: Psu Help!?!?
    http://www.newegg.com/Product/Produc...82E16817341002
    I would think that PSU would handle just about anything. I'm sure there are much better ones out there though. Just newegg it and narrow your search to what you want.
    Nov 2006
    I need over 26 Amps, that says 18 A under 12V. Any other responses. Although those OCZ PSUs are supposed to be excelletn (-P
    Nov 2006
    Bump, please I really need some responses.
    Nov 2005
    Scotland, UK (NOT England)
    This one hits out 35Amps. Try searching for it on NewEgg?
    -Dave
    Case Wizard
    California, USA
    Quote Originally Posted by Arden View Post
    The OCZ should be fine. The 18 A on the spec sheet isn't what you should be looking at. That number doesn't "matter". What you need to know is the total Amps on the 12V rail, so you need to add up the Amps on every 12V rail. But that 18 Amps does'nt tell you the total output it gives. It is more like the max Amps that could be delivered through that rail. But in actuality, it may be only possible for a particular PSU to deliver 16 A. I think you want to use this equation:
    Total Watts on the 12V rails / 12 V = Amps on the 12 V rails
    Gaming Console Modder Mitternacht's Avatar
    Nov 2006
    Pennsylvania
    Quote Originally Posted by Crimson Sky
    I never like get into a battle of wits with an unarmed opponent.
  1. Blown PSU?
    By dr-00 in forum Motherboards, Processors, & Power Supplies
    Last Post: 12-09-2006, 07:02 PM
  2. Dual PSU case
    By 3xtreme in forum Works in progress
    Last Post: 12-07-2006, 01:48 AM
  3. [Guide] How to make a test psu
    By DannyGlass in forum Electronics
    Last Post: 07-10-2005, 03:28 PM
  4. How can I make a PSU smaller?
    By DRece in forum Modding Q&A
    Last Post: 06-22-2005, 03:28 AM
  5. PSU shopping question
    By snake_0iler in forum Motherboards, Processors, & Power Supplies
    Last Post: 05-13-2005, 10:14 PM
