ya your right, I just tested the set up with a hard drive myself and find the same as what did, that it can work with a hard drive.
OK, let take a deep breath and go through the steps again.
1 the power supply was taken out of a working machine and was noted that it was in itself working.
2 You followed an online guide on how to make a stand alone psu and found the proper green and black wire on the atx connecter.
3 You cut the proper green and black wire and tape them or some sort of fashion that those were the wires to use.
4 You than cut down the access wires or you used some sort of fashion to have them out of the way.
5 You than proceeded to strip and connected the green and black wire to a switch or just temp connected them thus having a switch in place somehow(
because that is what makes them stand alone by having your own switch in place of the motherboard).
6 Than you proceed to connecting a device (
cdrom, hd, whatever) and than plugging in the psu that you modded and while it is on and plugged in you connected the green and black and kept them connected by twisting them together thus creating a switch on effect but in the end you got nothing
Is this all correct?
