Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Hot Rod Mice
    Strip it, paint it, and love on it... Commando's Avatar
    Nov 2006
    29 Palms CA
    Default Hot Rod Mice
    Hey everyone. I just wanted to share 2 more mice I did.
    The first one I did for my brother. It's a brand new Logitech LX3.
    The second one is an old one I had laying around. I wanted to try out some new red sparkle paint I had.
    I've got a couple more pics in my gallery, here.
    Take it easy.
    Undead Pirate d_stilgar's Avatar
    Philadelphia, PA
    Default Re: Hot Rod Mice
    Very cool. I need to get going with my airbrush. Everyone else is getting me jealous.
    Nov 2005
    Scotland, UK (NOT England)
    Nice, +Rep dude.
    -Dave
    Nov 2006
    Montréal
    really nice. Impressive Airbrush skills. +rep
    On a side note, I'm so lucky, my new girlfriend's doing airbrush...
    Nov 2005
    New girlfriend? Already? Impressive. The force is strong in this one...
    -Dave
    Nov 2006
    Montréal
    -Dave
    The same, I mean the Metalhead one I've speak of 2 weeks ago. I was turning around her for the last 9 months.
    Now let go back to the topic, sorry Commando, dont want to hijack this.
    Sep 2005
    Doylestown, PA, United States
    That's ridiculous commando. Seriously, you have some crazy skills.
    Maybe it's my airbrush.. but I can't get it within half an inch of my work area without it globbing up or spraying too much. Also, when I spray anything (like the mouse I'm painting right now) I get terrible orange peel with my Paasche VLS.
    Either way, you have some mad skills. +Rep.
    Typo:
    Overclocked Ronyx's Avatar
    Melbourne, Australia
    w00t
    +rep =D
    now can u do up a Logitech G5
    lolz i hate that red copper coloured dot in the middle of it...
    Nov 2006
    29 Palms CA
    Hey tybrenis,
    I still have the same problem with this my Eclipse CS. The whole globbing thing is not having the paint thinned out perfect. Don't get me wrong, this isn't as easy as it sounds. Too thin and you get a watery mess. Too thick, gobb city.
    Having a good compressor that can push 35-40 Psi consistently does help tremendously. Don't get discouraged though. I have the same problems and make the same mistakes. When my airbrush will all the sudden not push paint, then wamm too much. I think this happens to everyone. I try to start spraying off of whatever I'm painting, then work onto it. As soon as I feel my brush starting getting gobbed up, I pause and check it. Then I clear it by pulling all the way back then down to spit any gobb out. When this just isn't helping, pour out the paint, mix another really small amount up and go again. But before loading more paint, push some airbrush cleaner through the airbrush. Cleaner is a little expensive, but water or Windex isn't. Just make sure you spray some water through it before putting in more paint.
    I like using water based paints like Createx or Auto Air. These do fine on top of enamel bases and under enamel clear-coats. They are easy to thin out with a little water. I like to mix paint in the tops from plastic bottles, they are the perfect size.
    I hope this helps.
  1. Optical vs. Laser
    By DireSandMan in forum The Rookie's Nook
    Last Post: 11-22-2008, 07:47 PM
  2. cleaning mice???
    By psychowit in forum The Rookie's Nook
    Last Post: 11-21-2006, 11:54 AM
  3. EL Wire and hot stuff....
    By BonelesWarior in forum Modding Q&A
    Last Post: 04-17-2006, 07:26 AM
  4. Project Hot Rod
    By Iceman1330 in forum Works in progress
    Last Post: 08-09-2005, 01:31 PM
  5. Mice
    By altec in forum Laptops, Portable Electronics, Phones, & PC Peripherals.
    Last Post: 04-05-2005, 04:49 PM
