which is the better heatsink: Zalman CNPS7000B-Cu or Thermalright XP-90C Heatsink with Panaflo 92mm? How big is the Thermalright XP-120 Heatsink and will it fit on a Asus A8V Deluxe? does anyone know?
xp-90c is the best heatsink on the market right now. it is big and heavier than the zalman but it will fit on any mobo.
what about the xp-120? how big is it?
"Hey look, the topic!! It's getting away! Quick catch it! *running* Must *running more* get on *panting* TOP...IC!!!! *collapses* "-Temmink
Intel Q9450 @ 3.2GHz
Asus P5E3 Premium WiFi
OCZ Platinum PC3-12800 1600Mhz XTC 4Gb 7-7-7-24
2 x Powercolor HD4870 512Mb in Crossfire
Thermalright Ultra-120 Extreme with Noctua 120mm 1300RPM Pressure Optimised Fan
Windows Vista Ultimate 64bit w/ SP1
very big. with a 120mm fan and the heatpipes on the side it is a monster. the xp90c outperforms it by 1C or so and its smaller, but if the x120 fits on ure mobo you could get that for quieter operation
remember to keep weight in mind. If you plan to be moving the system around for lan parties and stuff, you want to be VERY careful with either one. I can damage your mobo due to weight
- Unknown
i can damage his mobo tooI can damage your mobo due to weight
ok smart a$$. You know I what I meant!!! LOL
- Unknown
Any way I can salvage my SP-97 for use on my socket 939? Haven't removed it yet from my athlon xp mobo yet to check how it would work out.
Those zalmans are heavy, i think the 7000 series all copper ones weigh 1 kilo sans fan.
If that system gets moved at all, I would look into somehow bracketing it to the case. No level of cooling is worth snapping your mobo in half. But then again.. that is living XTREME!!
/insert flashy graphics, guitar squeals and boobs.
no heatsink weighs 1 kilo. you dont have to be that worried about it because they have brackets on the back, just a little bit careful when moving.
