Hey guys, I'm really new to the modding world and just had a few questions.
I wanted to cut some designs into my case using a Dremel Tool, and was wondering if anyone knew what the best way would be to put the designs onto my case before cutting? Should I trace or what? I have no idea.
Secondly, does anyone know where I can purchase the Flexi-glass or maybe another better material to put inside the case behind the cuttings?
Third, is it best to connect LEDs and Cathodes into your power supply, or use an alternate method?
Fourth, if I wanted to paint my case, whats the best kind of paint to use? And should I do anything special to the case?
Thanks in advance for whatever help I recieve.![]()
