Results 1 to 7 of 7
Thread: Bit'a help please guys?
    Apr 2007
    Default Bit'a help please guys?
    Hey, didn't really know where to post this so I'll try here, 'cause I know you guys are nice 'nd friendly
    I'm wondering if this setup will overheat, and if so where I could install fans to cool it... I'll give ye all the details
    *If some of the stuff isn't necessary I'm not sure what effects temperature as I'm new to this*
    Motherboard
    Case
    PSU
    CPU
    HDD
    GPU
    Wi-Fi card
    Optical drive
    RAM
    Thanks!
    Chester UK
    Default Re: Bit'a help please guys?
    On the question of cooling It really all comes down to the case I dont really know much about that perticular case but if you wanted to add more fans one to the side panel or roof may help cooling. It might affect nosie more then cooling but psus with 120mm fans are normally better.
    Heres what case i would advise nice fan setup and looks pretty cool.
    http://www.custompc.co.uk/custompc/r...-phong-ii.html
    Feel free to ask anything else oh and welcome.
    Sir k
    CAN YOU WIN PLAYER OF THE WEEK!!!
    http://steamcommunity.com/groups/tbcs
    Apr 2007
    Quote Originally Posted by sirkillalot617 View Post
    On the question of cooling It really all comes down to the case I don't really know much about that particular case but if you wanted to add more fans one to the side panel or roof may help cooling. It might affect noise more then cooling but psu's with 120mm fans are normally better.
    Sir k
    Thanks!
    How would I go around installing fans into the roof and side?
    I'd rather stick with my Tsunami case TBH.
    Jun 2006
    In the Redwoods
    That is a good case with good airflow. You shouldn't have to worry about the heat buildup.
    Welcome to TBCS! and thanks for posting!
    Apr 2007
    Quote Originally Posted by Airbozo View Post
    Just the answer I was looking for thanks very much, for that I give you positive reputation!
    Spam Sniper SgtM's Avatar
    Jul 2005
    Ohio
    Agreed, and welcome aboard!
    Apr 2007
    Quote Originally Posted by sgtm View Post
    Tank'oo
    r j00 SLi enableled n00b?
