Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Capture cards
    Since 2006 DaJe's Avatar
    Aug 2006
    Massachusetts
    Default Capture cards
    I have two capture card questions. First off, I'm looking for one that has two coaxial inputs to it. If it has even more than 2, that'd be great. All I seem to be able to find are cards with 1. Even if a card with 1 inpu is my only option, I'd still like a suggestion as which one to get.
    My second question, is I'm looking for one that has component inputs, that could record in HD. I've seen other peoplelooking for that before too. It's something I'venever come across. Does it even exist for users such as us?
    Overclocked
    Apr 2007
    Default Re: Capture cards
    last i heard about component is that companies arent investing in making hd capture cards yet because the system is too new for most ppl that dont want to drop 600 for a newtv 400 for a new tuner and 300 for a burner
    "Two people can keep a secret only if one is dead." Abraham Lincoln
    Undead Pirate d_stilgar's Avatar
    Philadelphia, PA
    http://www.hauppauge.com/pages/produ...pvr500mce.html
    That one has a dual tuner. Hauppauge is also pretty much the best.
    Banned Eclecticos's Avatar
    Apr 2007
    Florida
    I agree get either a Hauppauge or AverMedia.
    Hauppauge is the best as far as internal capture cards go.
    Avermedia is the Best for external comes with a remote.
    Aug 2006
    Massachusetts
    One says TV in and one says FM in. Can both inputs be used for video recording?
    Apr 2007
    Florida
    What you need is a AV selector switch.
    and a capture card.
    If thats not the case and your planning on recording dual video simultaneously you better have one hell of a machine. .
    i'm talking quad core. with 8GB of ram.
    Aug 2006
    Massachusetts
    What if it's a machine dedicated to just recording video all day long
    Apr 2007
    Florida
    I would recommend 2 separate cards then for sure! Otherwise your going to have some real sound issues.
    Aug 2006
    Massachusetts
    Yeah, I planned on having two cards, but there are only 3 PCI slots, and there are 3 devices that need recording. And perhaps a wireless card would be used. Ah **** it, I'll just get 3 cards and then an ethernet cable. No sound needs to be recorded by the way.
    Apr 2007
    Florida
    Like Video Cameras? If so you can easily do that with one card if you have Bnc Connectors.
    You can swap out the coaxial for bnc just change the end adapter. Or get a coaxil to bnc adapter.
