Hey guys. Local Mod n00b here :p
I'm planning on building a mini itx system with a totally custom case Now i've built computers before and have been doing research on the computer hardware side of things and I have it all figured out ... for that part.
What I want to do is build a custom case, but very cheaply and would like to know what materials are best for a beginner with no advanced tools or extreme funds. Just really doing this for a hobby, not a full time position or anything.
I have idea for pvc piping for the edges and bondo to join them and give a nice smooth finish. Basically what i'm going for is something generally the size of a gaming console (a little bigger) that will be used for gaming and as a HTPC I want something modern, sleek and with a piano black finish *drool*
Eh, back to the question though, what materials would you recomend for the construction of the case? Something easy to cut, not too expensive, light and definately not conductive XD
Another thing to ask is, is there any spray that you can spray onto a material to make it stronger? Like a lacquer or something that dries very stiff and can be painted over? To generally add strength to materials?
Thanks for the help. All is appreciated. I searched the forums as well and could't really find any solid answers.
