Thanx to the insperational worklogs of Defyant and TBCS forums , i've been able to tackle this mod i've been working on for a co-worker friend of mine. Lucky for me, he is in no rush to get it back (cause time is not my friend). It's taking me a while to do this mod cause i've been crazy busy and i'm sure most of you can relate. I'm no good at making worklogs and taking pictures when i'm supposed to so you might find some gaps between work; bear with me here .
Left and right cut outs to start off (deffinately not the end of cutting)
Bottom and top cut outs
I needed to cut some of the molexes that i won't be needing and extend one of them to about 2 1/2 - 3 feet long to reach the front/bottom of the case.
Mini Sub + left and right speaker Mod (why: Because I can!)
Front bezel progress... sides: Cut out some holes for Power, Reset, cd-rom eject, usb ports, mic, and headphone jack
1st 2 pics: where did that floppy drive hole come from?
To give you an idea of the harddrive fan tunnel...
cd-rom mod: the top panel doesn't quite look like this anymore cause i scrapped the sheet metal and used the top of another case and bent it to fit. (did i forget to mention that he lost the top panel ) I'm still keeping the same concept though.
Front & right (i think that's the right side) schematic, if you can't read the red, it says hard drives
Painting of front, top, left and right bezel/panels
So I still have plenty to do and am far from over. The best part is that this mod won't even break 100 bucks (0 dollars from me). Hopefully more updates to come soon...
