My Computer please LOOK and tell me what u think
This is my first mod so im not sure how well of a job i did but im pleased with it. I painted the inside of my thermaltake tsunami case a worn copper. I replaced all the stock fans inside with aerocool fans. Replaced the video card stock cooler with a zalman. I have 2 blue ccfl lights inside and 2 blue ccfl lights on the underside of my case. I cut the hole in the top of my case to put the 120mm intake fan in. (intake there gets me lower temps than outtake) im pushing between 300cfm and 350cfm of air through my case depending on what i have my fans set at. I installed a zalman fan controller in the front of my case, tight fit with a case door. I also installed a biohazard window app. as you can see. Hope to hear what everybody thinks of my case and thank you for visiting it!
My Paint Job!!!
Re: My Computer please LOOK and tell me what u think
you can see where my dremel skipped off and i tried to fix its not visible normally!!!
Link To Original Thread
