Results 1 to 6 of 6
Thread: cherynobl idea
    Apr 2007
    Default cherynobl idea
    Hey, im thinking of building the main building (that i know of) in cherynobl (place of nuclear meltdown)
    What would be the best way to make this? im thinking of wood and then cover that in areas with plexi (wood for its ease of cutting, making, ect) and then paint it in a old adbandoned look. I got some of that silver piping (the stuff like in orac) which ill sand down the shinyness and add some rust color. To make the tower ontop, anyone know the best method? Thanks, Taintedplay
    Banned Eclecticos's Avatar
    Apr 2007
    Florida
    Default Re: cherynobl idea
    I think someones already beaten you to it if i'm not mistaken.
    Click Here
    DerGanove Ichbin's Avatar
    May 2006
    In the World of Tommorow!
    Just because its already been done doesnt mean you shouldn't do it.
    Improve on it and add your own flair.
    If you make it outta wood it might be a beasty to lift.
    hmmm...
    Id go with that most likely.
    I stole p0Pe's cake FrooP's Avatar
    May 2007
    in your fridge
    lol sounds like a competition, do you make it explodet like me or just how its on the pcture?
    May 2007
    well you could make it special with the feature of maing it from almost depelted uraninium
    Jun 2007
    MD
    if ur tryign to make it like it was right after the explosion you should have a jaggedy hole on the top that exposes the core...have like either green or purple light and paint uv reactiv pain ton the jaggedy parts of the hole...good luck i love the idea
    "Live your life well, for it will be short"
    -Unknown..
