Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Im stuck on these two
    Greco101
    Guest
    Default Im stuck on these two
    ASUS Striker Extreme
    NVIDIA nForce 680i
    I'll be running:
    E6700
    8800GTX (sli later down the road)
    and memory, I'm stuck between:
    OCZ Reaper HPC Edition
    OCZ Flex XLC
    Just a note... this will be my first build so I'm pretty inexperienced in this area
    EDIT: It will be used for gaming
    . Spawn-Inc's Avatar
    Feb 2007
    Default Re: Im stuck on these two
    i think i remember you saying you would water cool it but not sure. so if your going to water cool go with ocz flex.
    as far as the mobo goes i still say go with the striker.
    Sound: Logtiech Z 5500
    Balhannah, South Australia
    I agree. It looks awesome aswell haha the new 680iLT boards look like crap.
    Project: Elegant-Li *NEW*
    Project: Alpha FINISHED
    Feb 2007
    the dfi one does, i don't like orange pci slots...
    i like the heatsinks on the striker.
    That's classified.
    Be mindful that it may limit your processor HSF selection.
    Greco, have you seen this motherboard? Much cheaper for similar capabilities.
    Banned Eclecticos's Avatar
    Apr 2007
    Florida
    I'm going to get this one: ECS PA1 MVP
    or ABIT Fatal1ty FP-IN9 SLI This one.
    Feb 2007
    Quote Originally Posted by Redundant View Post
    thats what i might go with if i don't get a striker. the striker board can fit the thermalright ultra120 extreme so it should fit most.
    Jun 2006
    The Dairy State...
    Ehhhh, not really. My eVGA has a similar layout as far as heatsinks go, and anything that is greater than 120mm (my guess) that isn't straight up like that heatsink is, isn't going to fit. My Blue Orb wouldn't even make it within 3/4 in. to the CPU. It's either tall heatsinks, or little heatsinks.
    RIP Bucko
    Jun 2006
    In the Redwoods
    I was able to fit the Thermal Take Sonic tower on the Striker extreme with a little bit of room to spare and will probably be the cooler I use. That or another silent solution (not water _yet_).
    http://www.thermaltakeusa.com/produc...1/cl-p0071.asp
    Check out this custy work log for pictures of the Sonic Tower on both the Striker and eVga 680i.
    http://www.thebestcasescenario.com/f...?t=5921&page=3
    Greco101
    Guest
    damn im nervous... haha.
    I'm trying to build a pc that will last a few years and be error free as possible so I was looking into water cooling and the 8800gtx so i can run duals later down the road.
    All the problems with these boards are freaking me out, especially because this will be my first build.
    is there by chance a surefire setup to go with that will be FAST, low temp, overclockable, stable AND reliable?
    ^pretty much how i feel right now
