Hey all!!! I am new to this forum and i cant wait to meet all of you. I have always viewed the mod progress on this website, but i have never really done a mod. I currently have a Raidmax Horizon case for my system. I have always been into cooling my PC. So i decided to find an old case in my garage, and do my first case mod. My plans are the following:
The Primary Side Panel: 4x 120mm green LED case fans as intake.
The Rear Side Panel: 2x 80mm Black case fans an intake on rear side of motherboard to cool the opposite side of the CPU and PCI/PCI Express slots via cutting 80mm hole in motherboard tray.
The Front Panel: 2x 80mm green LED case fans as intake (No cutting required).
The Rear Panel: 1x 80mm green LED case fan as exhaust (No cutting required).
The Top Panel: 2x 80mm green LED case fans as exhaust.
The Bottom: 2x 120mm green LED case fans as intake.
Once all the fan holes are cut, I plan on painting the case black inside and out. I will use all my current hardware, except for an AeroCool Gatewatch 2, which i plan on buying after i get finished. Just to explain the rear side panel fans. I am going to cut two holes to accommodate 2 80mm fans that will be outside of the rear side panel, blowing in air straight on to the back side of the motherboard to cool the component on the other side. I will cut a hole in the motherboard tray also to let the air pass through.
Here are the first pics of the case before i will start:
The front and front side panel of the case:
The inside of the case (if you cant read the text, save the image and zoom in)
A good view of the bottom and top of the case
