ok so i have an old computer and it was on during a storm and the power went out (not surged) for a second and it restarted and when it booked back up it gave a blue screen and said UNMOUNTABLE_BOOT_VOLUME with a bunch of stuff under it like
if this is the first time restart yada yada yada
then it said if you installed new hardware (which i didn't) then uninstall it.
anyhoo i've had this happen before (or thats what my dad says) and it's resolved it self iver time. i was never there to see it happen. so i was messing around in bios and i started to overclock the cpu to see what would happen and i went from 100MHz (not the total what gets multiplied i think) i went to 105 then restarted and it said it was 1.68GHz. then i went to 110 and it said 1.76GHz. then i for a laugh i set it to max at 200 and it won't load up now, anything. what happened and how do i fix?
i'm thinking i have to pull out the battery for a couple of minutes.
Edit 800th post !
