Trust me, I've been googling, and I'm not coming up with much. Can someone help me with specs on a Ford 8.8 rear axle?
Max HP it can withstand stock
what spline axles it has
4-link setups
etc.
4-link setups
etc.
Originally Posted by Crimson Sky
The ford 8.8 comes in both 28 and 31 spline
Specs:
10 Bolt
8.8 Ring Gear
Ratios:
3.08 3.27 3.55 3.73 4.10 4.56
Info:
Application:
Ford: 1983-Up Bronco, F-150, 4.0 Ranger, Explorer
Mazda: 1983-Up Navajo
http://www.modularfords.com/forums/a...gear-specs.pdf
thats about all I came up with.
Well the Mustang axles are different from the trucks. Maybe I should of specified 8.8 Mustang rear ends.
Cause we're all friendly and warm inside.
And we like bunnies.
Which seem to start multiplying every time I turn around and try to type something in MY KEYBOARD !!!
We've got the spline already, 28.
Max HP... I think experience would speak best.
I'm going to ask some of my neighborghs to see if they have any idea..
As to 4-links... You want "links" (net) for the 4-link setup?
Or just general info?
Links for the links! LoL
You're in TBCS?
You do realize we're following a guy that's the
VP of Regional Sales for
Darth Harrington's Intergalactic Proton Powered Electrical Tentacled Advertising Droids
I'm just sayin'...
Kinda ironic, eh?
There's all kinds of custom 4-link setups with 8.8 axles, but I haven't found kits yet to do it, like bolt-in kits. And how much it would be; that kind of 4-link info.
And I have about 450-500 HP, and I need to know what in the axle I should upgrade before I add slicks. If the differential is weak, launching with slicks will shatter it. So if that's the case I'll buy a Detroit Locker or an Eaton Posi.
Just little information that could make the difference between making it or breaking it, that's all.
I was just trying to be helpful.
You're in TBCS?
I'm just sayin'...
