Results 1 to 5 of 5
Thread: cathode inverter to 12V
    Jul 2005
    Default cathode inverter to 12V
    i have a vantec fan and light controller on my new PC. it has three knobs for controlling fans and one knob attached to a built in cathode inverter. my case is the aspire X dreamer II which has very bight LED lights on the front that can become anoying from time to time. right now the only way to turn the lights off is to open up the MOBO side of the case and unplug them. is there a safe, relitivly easy way i could have the cathode knob work the lights on the front of my case?
    Jun 2005
    Pittsburgh, PA
    Default Re: cathode inverter to 12V
    If you could find a 4pin to 2pin (I'm assuming since its cold cathodes) converter thing with a pass through yes.but then youd need a 2pin y splitter to make them work all at the same time.
    Jul 2005
    i dont have any cathodes pluged into it. and was worried about overloading my LEDs since the voltage is much higher
    Jun 2005
    Pittsburgh, PA
    well is the connecter on your vantec a 3 or 2 pin connector for the cathode potentiometer (knob)?
    Jul 2005
    i beleive it is a two pin. the type that i have commonly seen on stand alone cathode inverters. the knob has 3 positions off sound reactive and on
  1. Cold Cathode Inverter setup
    By FynexFox in forum Idea Zone
    Last Post: 06-22-2006, 04:49 PM
  2. uv cathode
    By Okkkay in forum Motherboards, Processors, & Power Supplies
    Last Post: 03-26-2006, 06:42 AM
  3. cold cathode problem
    By ForceFedFlesh in forum Motherboards, Processors, & Power Supplies
    Last Post: 02-28-2006, 02:31 AM
  4. Cathode Lights
    By Ascoates in forum Modding Q&A
    Last Post: 12-27-2005, 01:01 PM
  5. 4 inches cathode or 12 inches cathode
    By kenga in forum Modding Q&A
    Last Post: 07-09-2005, 01:48 AM
