Ok so I have this new agp card.
It works when I dont plug in the 4 pin power.
When I plug it in my monitor gets no signal?
My PSU meets al the requirements.
Whats the deal?
Whats the deal?
what card, system, and psu u got?
Sound: Logtiech Z 5500
Its for my old dell.
Its a eVGA 7600GS with a 400w Dell PSU and a 3.0Ghz P4.
well try reinstalled the card (physically) and plug in the power first then put it in the slot. thats all i can think of right now.
If you were using an onboard, it may be conflicting.
Right click>properties>settings
Select your onboard card, then go to advanced. click on adapter>properties and disable it.
Yay I fixed it!
Supposedly it somehow killed my DVI wire.
I didn't know wires that thick could be fried?
