I have done one mod before, it was a simple case-paint mod for an older computer that I am using as a server.
Now I'm moving on to something a bit different.
I am a huge Dreamcast lover, and although my collection is somewhat small, my DC gets more play than even my 360.
So I heard that you could hook up a DC to a computer monitor via a special VGA cable. After reading about it more, I decided that I should invest in one of these. Now I don't have a HDTV or even an LCD monitor, but I figured hey, if it beats composite and is inexpensive than I might as well go for it. So I found a 17" Dell monitor at my Dad's work and took it home.
I plan on ordering a DC VGA box from eBay soon. The one I am looking at includes ports for Composite and S-video in addtion to the VGA-out. This will require me to get a (fe)male-to-(fe)male connector/cable. Where can I get one for cheap?
I plan on painting it white and possibly a part of it grey to try and get it to match. I'd like to try and add a Sega logo in grey, and if possible the dreamcast swirl on the top of the monitor in orange.
I already bought some white spraypaint, and I tried to get it to match as well as possible. I couldn't find any suitable grey paint, but then again I have only checked one store.
The LED to indicate that it is on is green. When the monitor is in standby mode, the LED changes to an amber, and somewhat resembles the DC's LED. I'd like to try and rewire the LED to do the opposite. That or replace the green LED with an Amber/Orange one I have on hand or can buy.
Here is a few pictures of the monitor and the DC next to it. Pardon the tail-end of my skimboard.
